Production Workflow
  • 1.  Inception and Visual Logic
    Posted 11-16-2018 18:15
    Hey guys,
    I'm running into an issue where visual logic is acting correctly in Xpression, but when using the Xpression MOS plugin in Inception the logic doesn't work correctly. Has anyone else dealt with this issue? If so how did you remedy it?
  • 2.  RE: Inception and Visual Logic
    Posted 11-16-2018 19:10
    Does your Visual logic work correctly in the preview window of the XPression sequencer?
    Does your visual logic use any datalinq values?
    Can you post any of the logic that isn't working?
    #Inception
