Inception News Version Number: 11.1.3 Build: 10885-6885
My question is, when the script is set to monitor in the Running Order, does it send the paragraph spacing for each rundown item to the teleprompter (Autoscript WinPlus IP). Everytime I preview the script in WinPlus IP after receiving the MOS from Inception, it leaves removing the Line Break spacing from the script, and then has to be manually formatted by the operator.
In the WinPlus IP settings, I've already set the import settings to have infinite spaces, and thus spaces work when importing other scripts. So I'm trying to figure out if this a a specific problem with this specific version number.
Thanks in advance for any help that can be provided.
