Connectivity
  • 1.  Web Control
    Posted 12-11-2017 09:56
    Hi Everyone,
    I'm looking for a way to control the NK router from a webpage, and I'm wondering if anyone has any ideas?
    This would be so that over Wifi the engineers can switch things without having to go back to the control room each time.
    It doesn't need to be overly fancy - just a select destination from a dropdown, select source from a dropdown and hit take.
    I'm assuming that it would have to work through dashboard somehow, but from what I've seen mentioned you can only add buttons to a dashboard Web presented page, so that is a little limiting for this.
    If anyone has any thoughts they'd be much appreciated.
    Cheers
    James
  • 2.  RE: Web Control
    Posted 01-07-2018 20:56
    +1 This would be very handy!
    #NK
  • 3.  RE: Web Control
    Posted 01-09-2018 22:08
    Hi timmohr,
    I've had quite a bit of progress on this asking in the Dashboard section.
    if you have a look here https://discussions.rossvideo.com/forum/default-forum-gc1/dashboard-gc43/14557-dashboard-webcontrol
    then you can see if any of this helps you out.
    Cheers
    James
    #NK
