  • 1.  Error when running Dashboard on OSX 10.15.5
    Posted 09-04-2020 22:22
    I can't seem to open Dashboard on my Mac. I uninstalled and reinstalled, and I'm still having the same problem. The attached popup comes up directing me to a log file, but that path doesn't seem to exist. Is anyone else seeing this behavior?
  • 2.  RE: Error when running Dashboard on OSX 10.15.5
    Posted 09-08-2020 14:07
    Hi Vincent!
    What version of Dashboard are you trying to run? Did it work previously, then stop working?
  • 3.  RE: Error when running Dashboard on OSX 10.15.5
    Posted 09-08-2020 15:41
    Hi Vincent,
    I don't typically run on a mac, so I don't have a lot of experience with them.   I talked to one of our developers who does run on a Mac, and got the following answer:
    The user is most likely not in the "staff" group.   Either add the user to the group or change the directory permissions for /Library/Application Suipport/openGear (and all it's subdirectories).
    Let me know if that helps.
  • 4.  RE: Error when running Dashboard on OSX 10.15.5
    Posted 09-30-2024 09:35
    4 years later and this answer was the solution for me. Thanks @Ben Gatien
    Ricardo Lezama
