you'll need to go to the code as Malcolm says, yours will look more complex than this as you have more and have data in them but this should give you the idea.
Sent: 10-31-2024 01:35
Subject: Dashboard Tabs
Off the top of my head, you can move things around but you have to get into the "source code". It's pretty much a copy/paste function. Another way around it would be to use buttons in the order you want the tabs to be. You can link tab visibility to the buttons, and then hide the tab positions by positioning them in the center.
Malcolm Thorpe
xpression design
Sent: 10-30-2024 14:31
This is going to be a somewhat silly, straightforward question, but I can't figure it out - in Dashboard, how do you move a tab? I have a group of tabs to keep various buttons and tables organized (see top of attached image for reference.) I simply want to take the "Standings" tab and move it in-between "Schedules" and "Top 10 Rankings." I've tried using the "Move" tool in Edit mode, but it moves every single tab instead of one individual one.
David Schuyler
Sports Producer
SCCTV
