Rather than Continuous animation you can use waveform block in Visual Logic, you'll see you can connect items to properties such as amplitude.
Sent: 02-07-2025 08:18
Subject: Xpression Scripting
Hi Simon!
Found this one again through searching.
And yes, this works well with a Continuous Animation, possibly with two tracks for position x and y set to random waveform to create a shaking effect.
However, is is possible like in AE to refer this back to a "slider"?
I've used invisible elements to do like a percentage animation based on heights etc, but it seems I cant access the "Amplitude" value of the continuous animation through for example visual logic? I probably can in VB, but was wondering if there's a way to go from shaking 0% to 100% (max value) shaking over time through Visual Logic.
Ohhh, and I'm testing this in XPression 9.5 atm. If this is possible in a later version, that's great. I just dont have access to it here.
Aleksander Stalsberg
Norway
Sent: 02-21-2022 18:56
You can script animations as but you'll need to know a little VB.net and it really depends on what you are trying to achieve.
If you want to do a wiggle I recommend using continuous animation or waveform block in visual logic.
