Never used Postman and not familiar with how to do so. I most likely do not have access, just trying to pull the source code of a public website so I can pull some roster info/stats from it. Some websites let me do it just fine, but others I get the 403 error, which I assume is from whatever header information the browser is sending that Dashboard is not.
Jake Lew
Access Communications Co-Operative Limited
Regina Canada
Sent: 05-16-2024 14:43
Subject: asyncPost HTTP request returns 403
Hi Jake,
Can you confirm using postman or any other tool if the request you are trying to send returns the data? It seems like you may not have access to the resource you are trying to access.
Thank you,
Aury R.
Aury Rukazana
Senior Software Developer
Sent: 05-15-2024 17:41
Anyone ever figure anything out about this topic? Running into it myself at the moment, and wondering if it was at all possible to get around.
Jake Lew
Regina Canada
Sent: 01-31-2020 22:06
An example of why this difference may have occurred overnight is that the website possible requires User Agent information from the DashBoard HTTP connection and may not have required this before.
Unfortunately, we have not encountered this behavior before, and there isn't currently a solution for this problem on our end.
