I have an Acuity with a single Multiprocessor input board. It's running 59.94 reference and our show is 1080i59.94. We have some old Panasonic HPX250 cameras and are testing the newer CX350 to replace them. We switch between 23.98 and 59.94 on-the-fly between music and speaking segments, as we like the slower frame rate for music. The HPX250 sends a ~60Hz signal at 23.98 and the Acuity accepts this, but the CX350 sends a 48Hz signal and the Acuity will not display the video. The CX350 has a menu setting for SDI output, and it indicates it's sending 1080 PsF, and there's no option to change it to something else except a lower resolution, which does display but looks terrible.
I'm inquiring to Panasonic why the difference, but is there anything the Acuity (or other gear) can do to receive and display the 48-50Hz signal? I don't know much about PsF, or why the two cameras are different. I read something about SmartConversion, but it doesn't seem to be supported on the MultiProcessor input card, and it may have nothing to do with frame rate anyway. I don't know if other outboard gear can up-convert a lower frame rate, and without adding frame delay, since the CX doesn't have genlock and we'd also be losing a frame to sync already with this camera - important for IMAG.
Thanks for any help.
Bryan Block
Malick Media
