Not via a menu.
You would have to do it with Custom Controls. What you could do is use CC Logic which would allow you to use user variables to Define conditions for which ones trigger based on what value you have set that variable too. Then even in other Custom Controls you would be able to define the User Variable Value to dynamically change these on the fly.
Sent: 06-25-2024 10:42
Subject: Acuity keyer transition link?
Hello All,
I want to link transitions between DSK1 and DSK4 on my Acuity.
I could not figure out if this is possible via the SETUP menu - which is my preference because I need to randomly/manually manage my DSKs.
The only way I could make this happen is via macro but using macros does not allow for random/manual key management.
Any thoughts?
Robert Vanrhyn
CNBC
