  • 1.  Adding Transitions to Lower Third video
    Posted 28 days ago
    Hi all,
    The lower thirds were built in Adobe After Effects and delivered as video files. I've put them through the video encoder and imported them into Xpression. The video animates in and out within the same clip/material. What is the best way to split the in and out transitions from within the clip so that it can be a triggered transition from the sequence?
    Michael Coursen
    New York Islanders
  • 2.  RE: Adding Transitions to Lower Third video
    Posted 28 days ago
    You can just drag onto the timeline and shorted to the frames you want.
  • 3.  RE: Adding Transitions to Lower Third video
    Posted 28 days ago
    Thank you! And this would be done from the scene director?
    Michael Coursen
  • 4.  RE: Adding Transitions to Lower Third video
    Posted 28 days ago
    yeah you need to make and IN and OUT and Null Scene director and then use Transition Logic for your IN / OUT and set default to NULL.
