  • 1.  Baseball Bug - update next batter
    Posted 03-14-2025 11:46
    We built  a new bug for baseball, displaying batter name and batting order number.
    For now I have a Dashboard dropdown list (1-9). Xpression uses that number as a datakey to read the row in excel to populate the batting order/Name info.
    This works fine but I have to replay the bug in for this info to update. Is there script/Logic for the info to change while the bug is online as soon as the Dashboard number changes to the next order number?
    JOSHUA KEAGY
    Xpression operator
    Blue Ridge 11
  • 2.  RE: Baseball Bug - update next batter
    Posted 03-14-2025 12:07
    Do you have live update turned on on the datalinq connection?
  • 3.  RE: Baseball Bug - update next batter
    Posted 03-14-2025 13:05
    I checked the requery scene datalinqs on data change and that worked, thanks!
    JOSHUA KEAGY
    Xpression operator
    Blue Ridge 11
  • 4.  RE: Baseball Bug - update next batter
    Posted 03-17-2025 05:26
    Excellent, you should only need that if you are using macros and you don't need it on every datalinq connections, I would only apply it to the main item that changes, it you turn it on on all connections it ay delay your scene going on air depending on how many.
