  • 1.  Black Storm Clip Double Take
    Posted 08-19-2024 16:40
    I'm having trouble with some of my video clips from the Blackstorm when running them through Overdrive.  I am using a Carbonite60.  When I run a couple of my shorter transitions it looks like the clip is re-cueing mid transition.  If I turn the play command off in the Custom Control it plays fine, but I need to play it before going to the transition.  Is there a way to turn the roll clip function off on just the Blackstorm in the dashboard?  I need the roll clip on ME P/P to play the video tapes from the Avid Server.
    Michael Fisher
    Sr. Production Automation Director
    Bellmedia
  • 2.  RE: Black Storm Clip Double Take
    Posted 08-19-2024 17:24
    Is OverDrive controlling the Black Storm servers or are you controlling them from the Ultra 60 directly?
    Can you post images of how you have the custom control configured?
    On the Ultra60 side there is no way to disable the Roll Clip for the server device individually.
    If Roll Clip is on just cutting the Keyer on for that BVS channel should roll the clip for you.
