Hi Steve,
Can you copy this code into a new panel file, create a txt file, copy code name the file with extension ".grid". Ex. NewPanel.grid.
Open this file and enter the address of the camera. Does this browser window have the same issue as your other panel?
Thanks,
Richard
<meta>
<params>
<param access="1" maxlength="0" name="url" oid="url" type="STRING" value="https://developer.mozilla.org/en-US/docs/Web/HTML/Element/img" widget="html-text"/>
<param access="1" constrainttype="INT_CHOICE" name="mode" oid="mode" precision="0" type="INT16" value="0" widget="default">
<constraint key="0">0</constraint>
<constraint key="1">1</constraint>
</param>
</params>
</meta>
<abs height="830" left="10" style="bdr#panelfg;bdr:round;" top="71" width="1460">
<browser bottom="10" fallback="true" left="10" right="10" top="10" type="default" url="%value['url'][0]%"/>
<abs height="60" left="10" style="bdr:round;bdr#panelfg;" top="10" width="1460">
<param bottom="10" expand="true" left="10" oid="url" right="312" showlabel="false" top="10" widget="default"/>
<button bottom="9" buttontype="push" right="2" top="8" width="290">
<task tasktype="ogscript">ogscript.reload(null);
</task>
</button>
Richard Crutwell
Ross Video UK
Sent: 08-09-2024 09:35
Subject: Browser Window Enlarged
Depending on which DashBoard version you are upgrading from and which OS you are on, you may be switching from your system browser (embedded MS Edge on Windows for anything after DashBoard 9.5 and embedded Internet Explorer for earlier versions) to an embedded Java Chromium browser called JX Browser.
In more recent releases (9.7+) JX Browser "Chromium" is the default on supported platforms. You can see what you are set to use and change your preferences in Window->Preferences->Browser Preferences
James Peltzer
Sent: 08-08-2024 20:48
This is a strange one. We have been using a custom panel as show below for about two years now without issue. It contains a drawer that displays a browser window for remote control of our Canon XF405 that we use to access gain and other functions quicker than the camera op can do using the menu and small LCD screen.
Now, for some strange reason the browser image displays as an enlarged (zoomed in) version as shown below. There is no way to change the size as there are no controls to do so. I tried checking with Canon but it appears the camera is no longer supported.
If I use a regular browser and type in the IP address of the camera, it displays as a normal size image with the browser:
Any idea what might cause this or know of a way to eliminate it? There was no change made to the code of the custom panel however, I did update my version of Dashboard from 9.6 to 10.1 but doubt that had anything to do with it.
Steve Witwicki
Video Technical Director
Light of Christ Church
