Thanks for your question.
Unfortunately the gang control enable/disable option is only available through the dashboard interface and is not exposed as an externally controlable feature. This means that you can't enable or disable this option through a remote control.
Mike Pomerleau
Sent: 06-11-2024 12:58
Subject: Change channel ganging settings with companion
I have two MC1s, one configured as master and the other as client. Thanks to Companion I can make changes to the matrix and thus control the PGM bus. The question is: Is it possible to disable channel Ganging remotely from the companion? Thanks
JOSE MARIA
