I was sending it to the DashBoard PC that was processing my Tally and custom panel.
Sent: 06-07-2024 07:40
Subject: Crosspoint Labels
can you advise what the communication settings for this outgoing connection need to relate to?
Dave Kennedy
Sent: 06-05-2024 17:00
Example of Ultrix Sending TSL UMD to DashBoard
Sent: 06-05-2024 16:55
And further yes you could setup TSL UMD from the Ultrix to send to dashBoard and get labels that way as well
Sent: 06-05-2024 16:54
Okay so yes very confusing at this point.
What Label Where are you trying to see this? If it is on an ultratouch then you should just be building SoftPanels for Ultritouch that you then open on that panel. All of those destination would automatically update. You would not be needing to create custom tracking an UI like this
Sent: 06-05-2024 16:29
I only have the Ultrix, with routing controlled by Ultritouch HR Panels as well as external triggers, I dont have a production switcher
Dave Kennedy
Sent: 06-05-2024 15:41
You have an Ultrix? and you have What Production Switcher?
Sent: 06-05-2024 15:18
Appologies, I believe i may have caused some confusion here as i now realise that i may have posted to the wrong community, as we have an Ulrtix routing system, not an Ultirx carbonite I dont believe i have the TSL UMD protocol available
Dave Kennedy
Sent: 06-05-2024 11:54
This should be done by setting up the TSL UMD protocol on the Ultrix to Send the source lables to the panel.
Then on the Carbonite for inputs you want to track you set the TSL UMD ID per input (on the input tab) and pick the correct ID and set it to LABEL only. Then it will update.
Sent: 06-05-2024 11:26
The idea is that the text changed is just a label on our touch panel, i imagine that the code would incrementally check which source is routed to a specified destination, pull its name from the source database and display that information, without any interaction on that panel. We have some cross points being triggered by external sources, the idea is that this would then follow any changed made to display live routing data.
Dave Kennedy
Sent: 06-05-2024 10:55
What exactly are you trying to do?
Chane the source labels on a switcher based on what is being routed to the switcher inputs from ultrix?
Sent: 06-05-2024 05:37
I am wanting to update a lable based on the source currently routed to a destination andlooking for some help.
I am quite new to this so have limited knowledge and currently working in the visual ogEditor.
Dave Kennedy
