  • 1.  Custom Control calling a Custom Dashboard Button
    Posted 07-03-2024 15:30
    I am using a custom dashboard panel (osc_send.grid).
    I want to be able to call the button on that panel from a custom control.
    Is this possible?  any tips on how?
    Thanks,
    Darryl Quinn
    Video Director
    Woodlands Church
  • 2.  RE: Custom Control calling a Custom Dashboard Button
    Posted 07-03-2024 15:58
    Yes-
    1-Edit the custom panel
    2-Double click anywhere in the background
    3-When the Edit Window pops up click on the top left corner
    4-On the right type in a port number in the internal Rosstalk GPI Listener
    5-Click on apply and close
    6-Double click the button you want to fire using a custom control
    7-Just above the tasks window there is a Trigger ID-enter a numerical value (1,2,3 etc)
    8-Once you assign a trigger id to the buttons save the panel
    9-On your switcher add a ROSS Talk Device using the IP address of the PC that has the panel you want to control making sure you use the port you assigned for the GPI listener
                    Carbonite: https://help.rossvideo.com/carbonite-device-db/Topics/Devices/RossTalk/RossTalk.html#RossTalk
                    Acuity: https://help.rossvideo.com/acuity-device/Topics/Protocol/RossTalk.html
    10) Once you add the device to your switcher create a custom control to trigger the button using RossTalk GPI command and the Trigger value you applied to the button. Using the RossTalk  GPI command
    Louis Santiago
    Senior Demo & Training Solutions Specialist - Prime, Switcher
    Ross Video | Let's make it real
    M: +1 (719) 367-2240
    Visit us at rossvideo.com
    This e-mail and any attachments may contain information that is confidential to Ross Video.
    If you are not the intended recipient, please notify me immediately by replying to this message. Please also delete all copies. Thank you.
  • 3.  RE: Custom Control calling a Custom Dashboard Button
    Posted 07-03-2024 15:59
    Louis Santiago
  • 4.  RE: Custom Control calling a Custom Dashboard Button
    Posted 07-03-2024 16:39
    excellent!  thanks for the detailed instructions!   Works great!
    Darryl Quinn
    Video Director
    Woodlands Church
