  • 1.  Custom Control (Macro) Timing Adjustment
    Posted 08-01-2024 11:36
    Hello all,
    I am trying to change the timing of a macro I built, but I cant figure out how to do so. Any help with extending a DVE Param shift time would be greatly appreciated!
    See attached pic.
    Thanks,
    Zachary McCrorey
    Sr. Creative Arts Director
    Transformation Church
  • 2.  RE: Custom Control (Macro) Timing Adjustment
    Posted 08-01-2024 12:19
    Hi Zachary,
    May I clarify that you would like to set the DVE X-position at 0%, wait a predefined amount of time while ME2 transitions, and then set the DVE X-position at 36.2%?
    To achieve this, insert a PAUSE event after the ME2 transition event.
    Custom Control > Pause > Set desired duration for the pause
    Aaron
  • 3.  RE: Custom Control (Macro) Timing Adjustment
    Posted 08-01-2024 12:42
    Thanks for the reply, Aaron. I would love to see the transition happen live (The key shifting from left to right smoothly over 2 seconds).
    Would you happen to know if that is possible?
    Zachary McCrorey
  • 4.  RE: Custom Control (Macro) Timing Adjustment
    Posted 08-01-2024 13:23
    Hi Zachary,
    I think I understand now - you would like to animate the transition. Yes, this is possible!
    So the animation will be achieved using Memories. Then the memories can be inserted into a Custom Control if you would like the animation to be a part of a larger sequence of events.
    1. You will need to create 2 different memories: one with DVE param at 0%, one with DVE param at 36.2%
    2. Set Recall mode to Effects Dissolve; and Effects Dissolve duration to 2 seconds
    3. Since our focus here is the DVE key, turn on key attributes for the relevant key
    4. Save the 2 memories.
    Now when you recall and toggle between the 2 memories, the switcher will interpolate the 2 different DVE parameters over 2 seconds.
    For a better understanding of memories, look at these 2 links.
    • https://www.rossvideo.com/resources/ross-university/carbonite-store-and-recall-memories/
    • https://rossvideo.community/discussion/carbonite-attributes
    The Carbonite U video (first link) is admittedly getting old, with an old color scheme and layout for the UI, but the concept still holds.
    Aaron
  • 5.  RE: Custom Control (Macro) Timing Adjustment
    Posted 08-01-2024 15:59
    I got it to work, Aaron!! Thank you SO much for your assistance!
    Zachary McCrorey
