  • 1.  Dashboard connectivity
    Posted 05-23-2024 10:03
    Can I save Dashboard settings from one computer to another?
    Clay Cantrell
  • 2.  RE: Dashboard connectivity
    Posted 05-23-2024 14:06
    Hi Clay,
    Yes you can.
    In your dashboard installation directory, you will find a workspace folder (Windows and Linux). That folder contains all your saved dashboard data. Copy it and paste it on the other computer.
    If you are on MacOS, the folder is in a different location, which is usually "/Library/Application Support/openGear/Dashboard". You will need to copy the ".metadata" folder to the same location on the other mac. You may need to show hidden files as it starts with a dot.
    Thank you,
    Aury R.
    Aury Rukazana
    Senior Software Developer
