Dashboard - Data after Changing openGear or Xpression Datalinq Configure
  • 1.  Dashboard - Data after Changing openGear or Xpression Datalinq Configure
    Posted 11-13-2024 11:17
    Hi everyone,
    Thank you for checking out my first post. I appreciate it!
    I built a custom panel using a Blank Self-Contained Data Source Panel because I'm using Xpression for sports graphics. Previously, I was able to pull data directly from the Dashboard to Xpression. However, since some of the partner companies are not using the Ross system, I want to modify my custom panel's DataLinq configuration to point to an XML file/Googlesheet instead.
    I tried to make this change, but it isn't working because the previously configured parameters are not sending data to the new XML file.
    Could anyone suggest a solution for this situation?
    Thank you!
    Wai Kin Ng
    Audio-Visual Engineer
    ASM Golbal
