Hi Max,
This is a known issue regarding version 9.9.1 and 'Send TCP Messages (String)' 's underlying rosstalk.sendMessages() ogScript command.
The issue has been resolved in 9.10, which is releasing within a week.
In the meantime, if you replace the existing ogScript command to be
rosstalk.sendMessage("localhost", 5250, [your message here]);
rather than
rosstalk.sendMessage("localhost", 5250, [your message here], null);
as it was previously, this will resolve your issue on 9.9.1 and allow you to send messages to the CasparCG server.
Michael Quach
Sent: 05-08-2024 11:26
Subject: Dashboard isn't sending TCP Messages
It simply was a visual logic Send TCP Messages with 127.0.0.1 as IP, 5250 as port and the string I wanted to send (a play command).
Downloaded Dashboard today so 9.9.1
Thanks,
Max
Max Rouard
Sent: 05-08-2024 11:22
Hi Max,
Would you be able to post the ogScript being used to send the TCP message, as well as the DashBoard version where you've experienced this issue?
Thanks,
Michael Quach
Sent: 05-08-2024 10:42
A few years ago, I used to work with an older version of Dashboard (6 or 7 something I think) and I used it to control a CasparCG server (mainly to play videos using Send TCP Messages (string)).
Now, new job, I try to replicate the process, but it seems like nothing is going out of the Dashboard. In parallel, the Caspar Client does send tcp messages and it works fine.
Is it something new ? Has anybody ever had the issue ?
Best Regards,
Max
Max Rouard
