Hello all,
got a query for you.
I am trying to make a copy of an existing project and copy across everything associated with it. This includes a dashboard and a bunch of files they have datalinqed. The error comes when I try to link to their excel sheets using the same technique they have (as an ADODB Datalinq source). When I try to set up the files in the same way, I get the following error message:
Failure: Provider cannot be found. It may not be properly installed.
I googled this and it said something about installing the following driver: [COLOR=#333333][FONT=wf_segoe-ui_normal]DB2OLEDBV6_x64.msi. I did this and I still get the same problem.
I was wondering if anyone had an experience with this?
And yes, I do have office up to date and installed.
Cheers[/FONT][/COLOR]
