  • 1.  Datalinq Excel Query and Xpression Designer 11.5
    Posted 07-15-2024 05:19
    I'm working with an Excel file and Datalinq.
    The following command : SELECT *  FROM [Competitor Results$] works fine in both Xpression 9.5 and 11.5
    But the following command : SELECT *  FROM [Competitor Results$] where position = 1 works fine in Xpression 9.5 but not in Xpression 11.5
    Any suggestions
    Regards
    Karim Lakehal
    VIDELIO - AMP VISUALTV
    Paris France
  • 2.  RE: Datalinq Excel Query and Xpression Designer 11.5
    Posted 07-15-2024 08:35
    I would recommend not looking through all of a sheet, it's better to make tables and look through those instead, checking the entire sheet can cause issues.
    Do you have multiple items which results = 1 in the sheet?
    Are you sure the value is an integer, have you tried checking if as a string?
    Would it not be better to look for a specific result rather than looking for "all" I am pretty sure XPression won't like it if it finds multiple 1's
  • 3.  RE: Datalinq Excel Query and Xpression Designer 11.5
    Posted 07-15-2024 09:26
    Hi Simon,
    I was more like wondering why the command : SELECT *  FROM [Competitor Results$] works fine in both Xpression 9.5 and 11.5
    when the following command : SELECT *  FROM [Competitor Results$] where position = 1 works fine on a computer with Xpression 9.5 but not on my computer running Xpression 11.5
    Could it be my computer or something ?
    Regards.
    Karim Lakehal
    Paris France
  • 4.  RE: Datalinq Excel Query and Xpression Designer 11.5
    Posted 07-15-2024 12:11
    What happens in 11.5 is more what I'd expect to happen if I am honest.
  • 5.  RE: Datalinq Excel Query and Xpression Designer 11.5
    Posted 07-15-2024 21:03
    Just curious what the settings are for that ADODB datalinq on that machine; it's possible that the true value of the cell in the excel sheet might be the character 1, as opposed to a number 1. I believe there's a setting for the connection string that's "IMEX=1" that could be appended. I would check to make sure that the connection strings for both Datalinqs look similar.
    If so, I would be curious if saying
    SELECT *  FROM [Competitor Results$] WHERE position="1"
    would work. Note the quotes " surrounding the data (telling the Excel sheet to look for text instead of specifically a number)
    Zachary Fradette
    United States
  • 6.  RE: Datalinq Excel Query and Xpression Designer 11.5
    Posted 07-16-2024 05:06
    If the 1 is a string and not a integer yes the quotes will work however you could still return 2 matching strings in which case I think XPression would still get confused about which one and even if it does return one of them how would you be sure which one it is returning.
    Do you know have a specific column you can check rather than searching for all for example;
    SELECT [NUM] FROM [TABLE] WHERE [POSITION] = 1
    I really would also recommend not connecting to sheets and instead make a table.
