  • 1.  DATALINQ IN VISUAL LOGIC
    Posted 09-27-2024 04:51
    I am using datalinq thru Visual Logic. But everytime i restart xpression the datalinq thru VL is disconnected. I then have to go to each datalinq control in VL and relink it to my database. I am using multiple datalinq control and it becomes time taking task to relink every individual parameter.
    Is there a way that the datalinq thru VL is always active like the way it is thru Object Inspector Data Source?
    Gaurav
  • 2.  RE: DATALINQ IN VISUAL LOGIC
    Posted 09-27-2024 14:51
    Sounds like a software bug.
    What version and build are of XPression are you using? Ex. v11.5 build 5555
    What is the Datalinq Source type? Ex. ADODB Datalinq Source
  • 3.  RE: DATALINQ IN VISUAL LOGIC
    Posted 09-27-2024 15:57
    Hi Garner
    I am using v11.5 build 5832.
    Data source is json and i am using Json Datalinq Source.
    Gaurav
  • 4.  RE: DATALINQ IN VISUAL LOGIC
    Posted 09-28-2024 10:32
    Hi Gaurav, even I had the same issue multiple times, so for its solution I took a separate text object and datalinked it.
    Later in visual logic scene objects selecting the new text objects(text property)>>> Text,  and used it in place of datalinq block. This fixed my problem. Please try it.
    Naga vamsi villa
    XPression Designer
  • 5.  RE: DATALINQ IN VISUAL LOGIC
    Posted 09-28-2024 11:18
    Hi Naga, thanks for the reply.
    I am doing the same process as mentioned by you.
    But just thought of highlighting the issue.
    Gaurav
