  • 1.  Datalinq table and Google Sheets
    Posted 10-24-2024 13:45
    I am familiar with using Excel Spreadsheets to pull data from Tables. The Table field in datalinq would look something like this:
    SELECT [COLUMN] FROM [TABLE NAME] WHERE [JERSEY] = @playernumber@
    I am trying to accomplish the same thing with Google Sheets and while I can get the datalinq to work, I have to publish each sheet individually, so there is no option in datalinq to select a "table". So, the question is, what do I put in the FROM brackets? Leaving it blank or removing the FROM section altogether doesn't give any results.
    Anyone have any success with tables in Google Sheets?
    Matt Finlayson
    Brigham Young University
  • 2.  RE: Datalinq table and Google Sheets
    Posted 10-24-2024 14:42
    Hey Matt!
    I'm fairly certain that using SQL queries is a function of the ADODB datalinq, so it wouldn't be availble to use for Google Sheets, which have to come in via the RSS/HTTP datalinq.
    Zachary Fradette
    United States
  • 3.  RE: Datalinq table and Google Sheets
    Posted 10-24-2024 15:47
    CDATA has software (purchasable) that can format Google Sheets as a database, and then you can use the ADODB datalinq to connect to CDATA.
    https://www.cdata.com/drivers/gsheets/
