  • 1.  Dropdown in a table cell
    Posted 26 days ago
    Is it possible to have a dropdown inside a table cell.
    And push the data from another table to the dropdown.
    So one table would have the player names and in the other table these names can be selected as the home and away players.
    <abs contexttype="opengear" dblinqport="2222" gridsize="20" keepalive="true">
       <meta>
          <lookup id="hosts">
             <entry key="local.port">7788</entry>
             <entry key="local.host">localhost</entry>
          </lookup>
          <params>
             <param access="1" constrainttype="STRUCT" name="Match Info" oid="params.matchList" structtype="com.rossvideo.matchinfo" templateoid="templates.matchInfo" type="STRUCT_ARRAY" widget="table">
                <value>
                   <subparam access="1" maxlength="0" name="MatchName" suboid="MatchName" type="STRING" value="Match One" widget="default"/>
                   <subparam access="1" maxlength="0" name="MatchNumber" suboid="MatchNumber" type="STRING" value="1" widget="default"/>
                   <subparam access="1" maxlength="0" name="MatchHomePlayer" suboid="MatchHomePlayer" type="STRING" value="Player One" widget="default"/>
                   <subparam access="1" maxlength="0" name="MatchAwayPlayer" suboid="MatchAwayPlayer" type="STRING" value="Player Two" widget="default"/>
                </value>
                <value>
                   <subparam suboid="MatchName" value="Match Two"/>
                   <subparam suboid="MatchNumber" value="2"/>
                   <subparam suboid="MatchHomePlayer" value="Player Three"/>
                   <subparam suboid="MatchAwayPlayer" value="Player Four"/>
                </value>
                <value>
                   <subparam suboid="MatchName" value="Match Three"/>
                   <subparam suboid="MatchNumber" value="3"/>
                   <subparam suboid="MatchHomePlayer" value="Player Five"/>
                   <subparam suboid="MatchAwayPlayer" value="Player Six"/>
                </value>
             </param>
             <param access="1" constrainttype="STRUCT" name="Player Info" oid="templates.playerInfo" structtype="com.rossvideo.playinfo" type="STRUCT" widget="table">
                <value>
                   <subparam access="1" maxlength="0" name="Name" suboid="PlayerName" type="STRING" value="Test" widget="default"/>
                   <subparam access="1" maxlength="0" name="Age" suboid="PlayerAge" type="STRING" value="Test" widget="default"/>
                   <subparam access="1" maxlength="0" name="Nationality" suboid="PlayerNationality" type="STRING" value="Test" widget="default"/>
                </value>
             </param>
             <param access="1" constrainttype="STRUCT" name="Player Info" oid="templates.matchInfo" structtype="com.rossvideo.playinfo" type="STRUCT" widget="table">
                <value>
                   <subparam access="1" maxlength="0" name="MatchName" suboid="MatchName" type="STRING" value="Test" widget="default"/>
                   <subparam access="1" maxlength="0" name="MatchAwayPlayer" suboid="MatchNumber" type="STRING" value="Test" widget="default"/>
                </value>
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="Confirm Prompt" oid="Confirm_Prompt" precision="0" type="INT32" value="1" widget="button-prompt">
                <config key="w.changeprompt">Submit changes?</config>
                <constraint key="0">Submit Changes</constraint>
                <constraint key="1">Submit Changes</constraint>
             </param>
             <param access="1" maxlength="0" name="rowstyles" oid="rowstyles" type="STRING" value="bg#000011;fg#ffffff" widget="default"/>
             <param access="1" constrainttype="STRUCT" name="Player Info" oid="params.playerList" structtype="com.rossvideo.playerinfo" templateoid="templates.playerInfo" type="STRUCT_ARRAY" widget="table">
                <value>
                   <subparam suboid="PlayerName" value="Player One"/>
                   <subparam suboid="PlayerAge" value="20"/>
                   <subparam suboid="PlayerNationality" value="USA"/>
                </value>
                <value>
                   <subparam suboid="PlayerName" value="Player Two"/>
                   <subparam suboid="PlayerAge" value="30"/>
                   <subparam suboid="PlayerNationality" value="CAN"/>
                </value>
                <value>
                   <subparam suboid="PlayerName" value="Player Three"/>
                   <subparam suboid="PlayerAge" value="40"/>
                   <subparam suboid="PlayerNationality" value="MEX"/>
                </value>
                <value>
                   <subparam suboid="PlayerName" value="Player Four"/>
                   <subparam suboid="PlayerAge" value="50"/>
                   <subparam suboid="PlayerNationality" value="AUS"/>
                </value>
                <value>
                   <subparam suboid="PlayerName" value=""/>
                   <subparam suboid="PlayerAge" value=""/>
                   <subparam suboid="PlayerNationality" value=""/>
                </value>
             </param>
             <param access="1" constraint="0.0;100.0;0.0;100.0;1" constrainttype="INT_STEP_RANGE" name="Selection" oid="Selection" precision="0" type="INT32" value="3" widget="default"/>
             <param access="1" constraint="0.0;100.0;0.0;100.0;1" constrainttype="INT_STEP_RANGE" name="SelectionMatch" oid="SelectionMatch" precision="0" type="INT32" value="0" widget="default"/>
             <param access="1" constrainttype="STRING_CHOICE" name="Table" oid="params.table" precision="0" type="INT16" value="0" widget="table">
                <constraint>params.array</constraint>
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="Confirm Prompt Delete" oid="Confirm_Prompt_Delete" precision="0" type="INT32" value="1" widget="button-prompt">
                <config key="w.changeprompt">Are you sure you want to delete the selected row?</config>
                <constraint key="0">Delete Row  -</constraint>
                <constraint key="1">Delete Row  -</constraint>
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="Xpression Selector" oid="xpression.selector" precision="0" type="INT16_ARRAY" value="0;0;3;2" widget="default">
                <constraint key="0">Player One</constraint>
                <constraint key="1">Player Two</constraint>
                <constraint key="2">Player Three</constraint>
                <constraint key="3">Player Four</constraint>
                <constraint key="4"/>
             </param>
             <param access="1" maxlength="0" name="Xpression Player Names" oid="xpression.playername" precision="0" type="STRING_ARRAY" widget="label">
                <value>Player One</value>
                <value>Player Three</value>
             </param>
             <param access="1" maxlength="0" name="Xpression Age" oid="xpression.age" precision="0" type="STRING_ARRAY" widget="label">
                <value>20</value>
                <value>20</value>
                <value>40</value>
             </param>
             <param access="1" maxlength="0" name="Xpression Nationality" oid="xpression.nationality" precision="0" type="STRING_ARRAY" widget="label">
                <value>USA</value>
                <value>USA</value>
                <value>MEX</value>
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="Confirm Prompt Delete Player" oid="Confirm_Prompt_Delete_Player" precision="0" type="INT32" value="1" widget="button-prompt">
             </param>
          </params>
       </meta>
       <table height="640" left="840" top="20" width="900">
          <tr>
             <table fill="both" height="515" insets="2,2,2,2" left="10" style="bg#dark;bdr:round;" top="15" weightx="1.0" weighty="1.0" width="1235">
                <tr>
                   <label colspan="2" fill="both" insets="2,2,2,2" name="Players" rowspan="1" style="txt-align:west;font:bold;size:Big;" weightx="1.0" weighty="0.0"/>
                   <button buttontype="push" colspan="1" fill="both" insets="2,2,2,2" name=" ▲ " rowspan="1" style="bg#lightdivider;size:16;font:bold;" weightx="0.0" weighty="0.0">
                      <task tasktype="ogscript">moveUp();</task>
                      <task tasktype="ogparamset">params.setValueRelative('Selection', 0, -1);</task>
                   </button>
                   <button buttontype="push" colspan="1" fill="both" insets="2,2,2,2" name=" ▼ " rowspan="1" style="bg#lightdivider;size:16;font:bold;" weightx="0.0" weighty="0.0">
                      <task tasktype="ogscript"/>
                      <task tasktype="ogparamset">params.setValueRelative('Selection', 0, 1);</task>
                   </button>
                   <button buttontype="push" colspan="1" fill="both" insets="2,2,2,2" name="  Add Row +  " rowspan="1" style="bg#23B126;size:16;font:bold;" weightx="0.0" weighty="0.0">
                      <task tasktype="ogscript">var newValue = {
             PlayerName: "",
             PlayerAge: "",
             PlayerNationality: ""
             var p = params.getParam('params.playerList', 0);
             p.setValueAt(p.getElementCount(), newValue);</task>
                   </button>
                   <param colspan="1" expand="true" fill="both" insets="2,2,2,2" oid="Confirm_Prompt" rowspan="1" style="style:toggleButton;bg#001FC1;size:16;font:bold;txt-align:center;" weightx="0.0" weighty="0.0">
                      <task tasktype="ogscript">//Set Dropdown Selection
    var length = params.getElementCount('params.playerList');
    length = length -1;
    var nameArray = new Array();
    for (i=0;i&lt;=length;i++)
       var name = params.getValue('params.playerList.' + i +'.PlayerName', 0);
       nameArray[nameArray.length] = name;
    params.replaceConstraint('xpression.selector', params.createIntChoiceConstraint(nameArray));</task>
    length = length -1;
    params.replaceConstraint('params.col3', params.createIntChoiceConstraint(nameArray));</task>
                   </param>
                </tr>
                <tr>
                   <param colspan="8" constrainttype="STRING_CHOICE" element="0" evenstyle="f:bg#tablezebra;" fill="both" insets="2,2,2,2" oid="params.playerList" precision="0" rowspan="1" showlabel="false" style="t:bg#696969;" weightx="1.0" weighty="1.0">
                      <config key="w.selectionparam">Selection</config>
                      <config key="w.reorder">true</config>
                      <config key="w.padding">10,15</config>
                      <config key="w.colminwidth.0">250</config>
                      <constraint>PlayerName</constraint>
                      <constraint>PlayerAge</constraint>
                      <constraint>PlayerNationality</constraint>
                   </param>
                </tr>
             </table>
          </tr>
       </table>
       <table height="640" left="40" top="20" width="780">
          <tr>
             <table colspan="1" fill="both" height="540" insets="2,2,2,10" left="1160" rowspan="1" style="bg#dark;bdr:round;" top="1360" weightx="1.0" weighty="1.0" width="1000">
                <tr>
                   <label colspan="3" fill="both" insets="2,2,2,2" name="Matches" rowspan="1" style="txt-align:west;font:bold;size:Big;" weightx="1.0" weighty="0.0"/>
                </tr>
                <tr>
                   <param colspan="8" constrainttype="STRING_CHOICE" element="0" evenstyle="f:bg#tablezebra;" fill="both" insets="2,2,2,2" oid="params.matchList" precision="0" rowspan="1" showlabel="false" style="t:bg#696969;" weightx="1.0" weighty="1.0">
                      <config key="w.selectionparam">SelectionMatch</config>
                      <constraint>MatchName</constraint>
                      <constraint>MatchNumber</constraint>
                      <constraint>MatchHomePlayer</constraint>
                      <constraint>MatchAwayPlayer</constraint>
                   </param>
                </tr>
             </table>
          </tr>
       </table>
       <table fill="both" height="460" insets="2,2,2,5," left="1960" style="bg#dark;bdr:round;" top="160" weightx="1.0" weighty="1.0" width="260">
          <tr>
             <label colspan="2" fill="both" height="40" insets="2,2,2,2" name="Home Player" rowspan="1" style="txt-align:center;font:bold;size:Big;" weightx="1.0"/>
          </tr>
          <tr>
             <param colspan="2" element="0" expand="true" fill="both" insets="2,2,2,2" left="13" oid="xpression.selector" rowspan="1" runtasksonload="true" showlabel="false" style="bg#3F3F3F;" top="501" weightx="1.0" weighty="1.0">
                <task tasktype="ogscript">var SelectedPlayer = params.getStrValue('xpression.selector', 0);
    length = length -1;
    for (var i=0;i&lt;=length;i++)
    var PlayerName = params.getValue('params.playerList.' + i +'.PlayerName', 0);
    if (SelectedPlayer === PlayerName)
    //Set Player Name
       params.setValue('xpression.playername', 0, PlayerName);
       ogscript.debug("SETTING PLAYER NAME: " + PlayerName);
    //Set Age
       var Age = params.getValue('params.playerList.' + i +'.PlayerAge', 0);
       params.setValue('xpression.age', 0, Age);
       ogscript.debug("SETTING AGE: " + Age);
    //Set Nationality
       var Nationality = params.getValue('params.playerList.' + i +'.PlayerNationality', 0);
       params.setValue('xpression.nationality', 0, Nationality);
       ogscript.debug("SETTING NATIONALITY: " + Nationality);
    }</task>
             </param>
          </tr>
          <tr>
             <label colspan="1" fill="both" insets="2,2,2,2" name="Name: " rowspan="1" style="txt-align:east" weightx="0.0" weighty="1.0"/>
             <param colspan="1" element="0" expand="true" fill="both" insets="2,2,2,2" oid="xpression.playername" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
          <tr>
             <label colspan="1" fill="both" insets="2,2,2,2" name="Age: " rowspan="1" style="txt-align:east;" weightx="0.0" weighty="1.0"/>
             <param colspan="1" element="0" expand="true" fill="both" insets="2,2,2,2" oid="xpression.age" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
          <tr>
             <label colspan="1" fill="both" insets="2,2,2,2" name="Nationality: " rowspan="1" style="txt-align:east;" weightx="0.0" weighty="1.0"/>
             <param colspan="1" element="0" expand="true" fill="both" insets="2,2,2,2" oid="xpression.nationality" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
       </table>
       <table fill="both" height="460" insets="2,5,2,2," left="2260" style="bg#dark;bdr:round;" top="160" weightx="1.0" weighty="1.0" width="260">
          <tr>
             <label colspan="2" fill="both" height="40" insets="2,2,2,2" name="Away Player" rowspan="1" style="txt-align:center;font:bold;size:Big;" weightx="1.0"/>
          </tr>
          <tr>
             <param colspan="2" element="1" expand="true" fill="both" insets="2,2,2,2" left="13" oid="xpression.selector" rowspan="1" runtasksonload="true" showlabel="false" style="bg#3F3F3F;" top="501" weightx="1.0" weighty="1.0">
                <task tasktype="ogscript">var SelectedPlayer = params.getStrValue('xpression.selector', 1);
    length = length -1;
    //Set Player Name
       params.setValue('xpression.playername', 1, PlayerName);
    //Set Age
       params.setValue('xpression.age', 1, Age);
    //Set Nationality
       params.setValue('xpression.nationality', 1, Nationality);
    }</task>
             </param>
          </tr>
          <tr>
             <param colspan="1" element="1" expand="true" fill="both" insets="2,2,2,2" oid="xpression.playername" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
          <tr>
             <param colspan="1" element="1" expand="true" fill="both" insets="2,2,2,2" oid="xpression.age" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
          <tr>
             <param colspan="1" element="1" expand="true" fill="both" insets="2,2,2,2" oid="xpression.nationality" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
          </tr>
       </table>
    Sam McIntosh
    National Rugby League
    Australia
  • 2.  RE: Dropdown in a table cell
    Posted 26 days ago
      |   view attached
    Hi Sam,
    Yes, it is possible to have the drop-down widget in the Struct table.
    Here is an updated version of the panel. I have altered the struct param and template for match info to accommodate the dropdown widget.
    There is an update button added above your selectors to update the match info table, it takes the choices from the xpression.selector param so the submit button function needs to be called before the update.
    Let us know how you get along.
    Richard Crutwell
    Ross Video UK
    Attachment(s)
    txt
    structTableDropdown.txt   19 KB 1 version
  • 3.  RE: Dropdown in a table cell
    Posted 25 days ago
    Thanks Richard, thats perfect.
    One last thing to tie this together. If I make a match selector can the home and away players for that match be updated in the player selector and show that data?
    Sam McIntosh
    Australia
  • 4.  RE: Dropdown in a table cell
    Posted 25 days ago
      |   view attached
    This solution requires you to hide the MatchSelection Param somewhere in the panel but is a useful trigger for updating the tables on selection.
    Richard Crutwell
    Ross Video UK
    Attachment(s)
  • 5.  RE: Dropdown in a table cell
    Posted 25 days ago
    Great, that is brilliant!
    Thanks again for your help, I can expand off this now.
    Sam McIntosh
    Australia
