Sent: 03-26-2025 05:42
Subject: Dynamic Material
Try ticking "requery datalinqs on data change" checkbox in the datalinq connection.
Sent: 03-26-2025 05:34
Hi Simon,
Yes the @TextPays@ mmacro is indeed connected to Datalinq, I've noticed that if the @TextPays@ macro is static then it's all good.
But using the Datalinq is causing the issue.
Karim Lakehal
VIDELIO - AMP VISUALTV
Paris France
Sent: 03-26-2025 05:05
Are the text macros connected to datalinq?
Sent: 03-26-2025 04:28
I have a little issue while using Dynamic Material in Datalinq, everything is almost Ok.
The only thing is that in the sequencer I have first to cue the scene in order to see the proper material if I do a take first, the material doesn't show up.
The material is a video.
When I use an image instead of the video it works perfect, no need to cue.
I tried both Path with a text object macro : E:\#WBC 2025\Video\FLAGS\@TextPays@.avi and a Materrial : @TextPays@
Any idea
Karim Lakehal
Paris France
