  • 1.  Explaining the Timer in Visual Logic
    Posted 02-18-2025 17:20
    Is it possible for someone to explain the timer and how it works in visual logic?
    Further, even if it is not possible with the timer, how can I use visual logic (if even possible at all) to detect when a value is not 0 display it for 7 seconds, and then fade it away?
    I'm a bit new to xPression, I looked at past posts, read documentation, and looked at xPression U and could not find a solution. Any help is appreciated.
    Elias Kutz
    Broadcast Engineer
    Bethany Lutheran College
  • 2.  RE: Explaining the Timer in Visual Logic
    Posted 02-19-2025 05:29
    https://www.rossvideo.com/resources/ross-university/counting-down-to-a-date-or-time-using-function-blocks-in-xpression-visual-logic/
