Connectivity
  • 1.  HDMI AUX SFP on Ultrix 5RU
    Posted 07-18-2023 05:33
    Hello
    I have 2x Tranceivers and 4x Receiver HDMI SFP for the Ultrix. Is it plug and Play for them to work as intended? or am i missing a step to set the port to Either Input or Output?
    regards
    Brian
  • 2.  RE: HDMI AUX SFP on Ultrix 5RU
    Posted 07-24-2023 09:04
    Hi Brian,
    Once you have placed the HDMI SFP's into the Aux ports you want to use you need to do the following
    1. Expand the Devices node.
    2. Expand the Controllers + Matrices node.
    3. Double-click the node for your Ultrix router. The Device Configuration interface opens.
    4. Select . The SFP Configuration page opens with the AUX Ports tab selected.
    5. From the Slots table, select the router slot for the port you want to configure. The tab updates to display a list of available ports based on the slot(s) selected.
    6. Locate the row for the port you want to configure.
    7. n the SFP column, select either SDI Video or MADI as appropriate for the fitted port.
    8. Click Apply to save your changes.
    Once you have done this you will also need to add the ports to your source and destination configurations.
    You can find some info in the userguide starting on page 124.
    The last step is to add the source and destination to a control panel
    Feel free to send an email or call support for adddditional help.
    Mike Pomerleau
  • 3.  RE: HDMI AUX SFP on Ultrix 5RU
    Posted 07-25-2023 07:03
    hello,
    I would like to thank you for your contribution, which allows me to advance my research.
    Cordially
