  • 1.  How to create an inverted alpha mask?
    Posted 7 days ago
    How do you create an inverted alpha mask or can you use a slab to mask out the material?
    Lea Guerrero
  • 2.  RE: How to create an inverted alpha mask?
    Posted 7 days ago
    To use a slab to mask out another object like a quad you can do this;
    Layer object
    Slab with corners for example, render all channels, be sure to put a material on your slab, I have used black here.
    On the quad to the alpha channel off.
    result
  • 3.  RE: How to create an inverted alpha mask?
    Posted 7 days ago
    If I put it in a group it wants to disappear. Do you know why that's happening? Is there a way to fix that ?
    When I put the image in a group.
    Lea Guerrero
  • 4.  RE: How to create an inverted alpha mask?
    Posted 7 days ago
    Logo Group is inside MainBuild folder that is why it is disappearing or maybe positioning?
  • 5.  RE: How to create an inverted alpha mask?
    Posted 7 days ago
    Ah that probably it. Thanks
    Lea Guerrero
  • 6.  RE: How to create an inverted alpha mask?
    Posted 7 days ago
    Did you zero out your group positions?
    If not this can happen, it's probably just shot of screen somewhere, try dropping the entire tree in a group and moving it back onto the screen.
  • 7.  RE: How to create an inverted alpha mask?
    Posted 7 days ago
    If you are using an image as a mask then you can invert in the mask image.
  • 8.  RE: How to create an inverted alpha mask?
    Posted 7 days ago
    Alternate Solution
    https://rossvideo.community/discussion/bw-images-as-a-mask-solution?ReturnUrl=%2fcommunities%2fcommunity-home%2fdigestviewer%3fcommunitykey%3d91812bfd-9393-4a3f-8a74-7f8035df130e
    Azathoth
    Son of Cthulhu
