I have question, How to use Transition Logic for Crawls? to change the position of Tickers(Crawls)
  • 1.  I have question, How to use Transition Logic for Crawls? to change the position of Tickers(Crawls)
    Posted 08-30-2024 04:23
    Hello I have 3 crawls running at same time. If i want to use transition logic to shuffle between position of those 3. what is the solution.
    In 3 bands of ticker, a group needs to be declared. If any single band of these three bands needs to be on or off individually, at the same time remaining bands should be repositioned automatically. For an example, once i takeoff the 2nd band, 1st band will be automatically drop down & positioned to the 2nd bands place. How can it achieved in a group scene ticker?
    AMIT DHAMANKAR
  • 2.  RE: I have question, How to use Transition Logic for Crawls? to change the position of Tickers(Crawls)
    Posted 08-30-2024 06:44
    I would look at a thread on racing results, I think that will  clue you into what you need to do.
    https://rossvideo.community/discussion/racing-results-leaderboard-animations
  • 3.  RE: I have question, How to use Transition Logic for Crawls? to change the position of Tickers(Crawls)
    Posted 08-30-2024 07:31
    Hello Red,
    I used trigger event for this but as I am using Crawl. crawl text is not changing position of text as per BG of Crawl text.
    As in this case I am using multiple Scene Group & Data pages.
    AMIT DHAMANKAR
  • 4.  RE: I have question, How to use Transition Logic for Crawls? to change the position of Tickers(Crawls)
    Posted 08-30-2024 09:36
    oh yes, this will require some scripting.
  • 5.  RE: I have question, How to use Transition Logic for Crawls? to change the position of Tickers(Crawls)
    Posted 08-31-2024 01:03
    Can any help with sample project or scripting please
    AMIT DHAMANKAR
  • 6.  RE: I have question, How to use Transition Logic for Crawls? to change the position of Tickers(Crawls)
    Posted 08-31-2024 12:11
      |   view attached
    You'll need to make the sub animations in the sub scenes and then find a way to trigger them.
    This isn't exactly what you are after but it will show you how I achieved something similar.
    You'll need to look at the GPI's to see all the scripting.
    Attachment(s)
    xpp
    Roll & Crawl No Datalinq.xpp   547 KB 1 version
  • 7.  RE: I have question, How to use Transition Logic for Crawls? to change the position of Tickers(Crawls)
    Posted 09-02-2024 04:17
    Thanks Red, Let me check this.
    AMIT DHAMANKAR
  • 8.  RE: I have question, How to use Transition Logic for Crawls? to change the position of Tickers(Crawls)
    Posted 09-02-2024 00:38
    Amit, how about u use Render View material? Create 3 different ticker crawl scene and bring these 3 scenes in to a 4th scene thru render view material... In the 4th scene u will have the option of positioning ur ticker crawls (i.e Quads) thru VL as per ur need.
    Gaurav
  • 9.  RE: I have question, How to use Transition Logic for Crawls? to change the position of Tickers(Crawls)
    Yup Gaurav. This is good alternative actually.
    AMIT DHAMANKAR
  • 10.  RE: I have question, How to use Transition Logic for Crawls? to change the position of Tickers(Crawls)
    Best Answer
    Posted 09-02-2024 09:25
      |   view attached
    Hi everyone.
    Amit try the attached project
    Roman Yaroshenko
    chief specialist
    RBC-TV
    Moscow Russian Federation
    Attachment(s)
    xpf
    Crawl.xpf   118 KB 1 version
  • 11.  RE: I have question, How to use Transition Logic for Crawls? to change the position of Tickers(Crawls)
    Posted 09-03-2024 01:21
    Hello Roman,
    This is awesome. Thanks a lot for this sample file.
    Regards,
    Amit Dhamankar
    AMIT DHAMANKAR
