  • 1.  Launch dashboard in fullscreen
    Posted 02-15-2023 03:46
    Hello, I would like dashboard to launch in full screen on our control laptop so that the panel renders correctly and also to avoid unwanted menu interactions. I found this response from a thread in 2017
    "Finally, as of DashBoard 8.3.1, you can also add -fullscreen true to your DashBoard shortcut to launch DashBoard in fullscreen mode."
    What exactly does this mean? What shortcut is this referring to? Is this still the best way?
    Sam
  • 2.  RE: Launch dashboard in fullscreen
    Posted 04-14-2023 17:00
    Hi Sam
    Yes, this launcher argument is still the best way to do this (particularly if you are running Windows or Linux).
    For Windows, you can create a shortcut to DashBoard and add the additional arguments that way.  You could also edit the DashBoard.ini file to do this (but this is overwritten each time you upgrade to a new version).
    James Peltzer
  • 3.  RE: Launch dashboard in fullscreen
    Posted 12-17-2024 08:49
    for anyone else that has this issue, I also used the same method to get my dashboard OUT of Fullscreen, my laptop for some reason or another wouldn't send the SHIFT+F11 shortcut to get out of full screen (I enabled Fullscreen via the menu)
    restarting dashboard would remember the setting, so I used the above method with -false and fixed the issue.
    Tom Wilson
    Demo & Training - Solutions, Oceania
