Live sorting of a standings-table
  • 1.  Live sorting of a standings-table
    Posted 6 days ago
    Hey hey,
    I was wondering if anyone here knows what it would take to create a scoreboard where the standings move depending on what the data changed to. So for example I have a excel sheet with points assinged to different teams, the table sorts itself automatically depending on what team has the most points. I would like the graphics to represent that but rather have the new order just pop into existence I'd like for the teams to actually move/animate into the new position. So basically imagine the Formula1 sidebar with the positions of the cars on the track and one of the drivers gets overtaken. The new order doesn't just plopp in, but the positions actually swap. F1 Excample when Kvyat goes from 12th place to 2nd
    YouTube remove preview
    F1 2019 TV Coverage - Bahrain - 2160p 4K 50fps (29.0 Mb/s bit rate) Footage (Channel 4 Commentary)
    As per request this is the 4k bahrain footage with channel 4 commentary dubbed over Format : MPEG-TS File size : 10.7 GiB Duration : 52 min 9 s Overall bit rate mode : Variable Overall bit rate : 29.3 Mb/s Video ID : 1535 (0x5FF) Menu ID : 553
    View this on YouTube >
    Also handy to know that while I'm doing rather ok with VL, I have very little experience with VB.
    Johannes Pedri
    Berlin Germany
  • 2.  RE: Live sorting of a standings-table
    Posted 6 days ago
    It requires scripting as you need to update the keyframe values with the items current position and tell it where its new position needs to be and then move it. accordingly.
    At the same time you must move all other items to their new respective positions.
    So every time the data changes you must re-evaluate every position, it's quite a complex graphic.
  • 3.  RE: Live sorting of a standings-table
    Posted 6 days ago
    Hi Simon
    Can you send this script?
  • 4.  RE: Live sorting of a standings-table
    Posted 6 days ago
    I would need to write it first as I don't seem to have any saved examples, I am working on a project with a pressing deadline at the moment.
    I will try to write something when I am done with project unless someone beats me to it.
  • 5.  RE: Live sorting of a standings-table
    Posted 6 days ago
    That would be amazing, even if my deadline for this won't allow me to use it, it will definitly come in handy at some point and I get to learn something new.
    Thanks for taking the time reading,
    Johannes
  • 6.  RE: Live sorting of a standings-table
    Posted 6 days ago
    Sure take your time thanks dear
  • 7.  RE: Live sorting of a standings-table
    Posted 6 days ago
    I expected it to be complicated so no surprises there. Thank you for the answer anyways.
    Johannes
  • 8.  RE: Live sorting of a standings-table
    Posted 6 days ago
    I will try to find time to make an example in the mean time this looks like a similar conversation on here;
    https://rossvideo.community/discussion/racing-results-leaderboard-animations#bmd7a974c3-eb80-40c3-8481-75e853eeb6e0
  • 9.  RE: Live sorting of a standings-table
    Posted 6 days ago
    group folder has the data for the first line i.e first name last name text if they are two separate objects...etc
    and the points is just the text.
    and of course the y position for all the lines.
    makes sense?
    good luck
  • 10.  RE: Live sorting of a standings-table
    Posted 6 days ago
    forgot to mention, i used this a long time
    ago and i forget if it swaps or pops on...you'll have to test it. ��
  • 11.  RE: Live sorting of a standings-table
    Posted 6 days ago
    The OG poster asked for it to be animated between positions, this will just jump positions.
  • 12.  RE: Live sorting of a standings-table
    Posted 6 days ago
    If you check this thread;
    And download Roman's project testt.xpp it has what you need just connect the "Pos_0/1/2/3" etc to your data for each position and you'll see it will work when you change the data.
    If you don't have data to test with you can use widgets.
  • 13.  RE: Live sorting of a standings-table
    Posted 6 days ago
    Downloaded the file, but somehow I can't compile any of the scripts. Could this be because I'm just on a designer licence right now?
    Johannes
  • 14.  RE: Live sorting of a standings-table
    Posted 6 days ago
    Correct you need at Developer or Studio to compile scripts.
