  • 1.  Looking for a way not to use Excel's legacy sharing.
    Posted 10-17-2024 09:56
    Now I'm trying to use an xlsm file, with VBA Macro, to establish Datalinq connection between XPression and Excel. Once I have completed it but can't save the file so often with "sharing violation" errors, it's a nightmare.
    Any another solution to this?. Anyone use xml or json outputted from Excel instead of the Excel's legacy sharing?.
    Takuya Hoshikaya
  • 2.  RE: Looking for a way not to use Excel's legacy sharing.
    Posted 10-17-2024 11:12
    I have heard of people doing it but it cam be a little bit of a pain from a file management point of view.
  • 3.  RE: Looking for a way not to use Excel's legacy sharing.
    Posted 10-21-2024 12:02
    Are you using the ADODB data source and the ACE driver?
  • 4.  RE: Looking for a way not to use Excel's legacy sharing.
    Posted 10-21-2024 19:10
    Yes, I choose Excel (XLSX) in the ADODB, and push the "Select Excel file…" button. And I choose "All Files" to find my xlsm file in the dialog box.
    I think Microsoft.ACE.OLEDB 12.0 supports not only xlsx but also xlsm (https://www.connectionstrings.com/ace-oledb-12-0/xlsm-files/). Am I correct?.
    Takuya Hoshikaya
  • 5.  RE: Looking for a way not to use Excel's legacy sharing.
    Posted 10-22-2024 11:52
      |   view attached
    Hi Takuya,
    Not sure if you've figured this out and I'm late to the game or I'm over explaining but here's what I had to do...
    Where the Datasource says [ExcelFile] map that to you excel spreadsheet. I have mine saved locally on my D drive but it can be anywhere as long as your PC has permissions. I've added a screen shot of my set up. Sorry if this is info you already know though or if it's not what you're going for.
    Donny Swanson
    Graphic Designer, Broadcast
    TVO (TVOntario)
    Toronto Canada
