  • 1.  Making Text Always Centered (with VL?)
    Posted 10-18-2023 14:57
    Hi all!
    I am fairly new to Ross; our station just got it a little less than a month ago. I am attempting to have up to four lines of text on a scene that will auto-center, auto-squeeze, and wordwrap. I've gotten through most of the hurdles, but I am stuck at the auto-center part. Screenshots are attached. Looking for any advice -- thank you!!!
    Sarah Husney
    Graphic Designer
  • 2.  RE: Making Text Always Centered (with VL?)
    Ross Staff
    Posted 10-18-2023 15:17
    Center vert or horizontal?
  • 3.  RE: Making Text Always Centered (with VL?)
    Posted 10-18-2023 15:31
    Vertically within the transparent white box.
    Sarah Husney
    Graphic Designer
  • 4.  RE: Making Text Always Centered (with VL?)
    Ross Staff
    Posted 10-18-2023 18:34
    Put the text in a group so you can position where you want it.
    Take the bounding box height of the text and devide by 0.5 and put that to the position of the text y position.
    The use the position of the group to put the text where you want it.
  • 5.  RE: Making Text Always Centered (with VL?)
    Posted 10-19-2023 12:34
      |   view attached
    Hi Simon!
    Thank you so much for this advice. Unfortunately, I cannot put all of the text in the same group, so I am grouping by text colors (white title text + white info text, yellow title text + yellow info text). Still, that solution was working really well! However, I find that whenever I get to the fourth bounding box height equation in VL, the whole thing breaks and none of the VL works. Would you happen to have a solution for this issue? Is there maybe something wrong with my VL?
    Sarah Husney
    Graphic Designer
