  • 1.  Material Server Channel Shader
    Posted 03-18-2025 10:29
    I've created a material applied to a quad on a scene 2 ( Framebuffer 2 )
    That material has a Server Channel Shader with Channel set to Server Channel 1 ( Scene 1 on Framebuffer 1 )
    What I expected then is Scene 2 outputing what is playing on Scene 1.
    Scene 1 is indeed playing but Scene 2 remains black.
    Any idea ?
    Karim Lakehal
    VIDELIO - AMP VISUALTV
    Paris France
  • 2.  RE: Material Server Channel Shader
    Posted 03-18-2025 10:41
    For me this works as you described;
  • 3.  RE: Material Server Channel Shader
    Posted 03-18-2025 11:33
    Hi Simon,
    Can you send me your project, I'm sure I'm missing something.
    Karim Lakehal
    Paris France
  • 4.  RE: Material Server Channel Shader
    Posted 03-18-2025 11:40
    I didn't save it but here are the settings;
    Make sure you're not trying to send the scene to the same framebuffer that the sever channel is trying to use as you can see above the server channel I want to use as a texture has no framebuffer assigned.
