Need a little help with a simple script. (helping out a fellow designer)
  • 1.  Need a little help with a simple script. (helping out a fellow designer)
    Posted 09-20-2024 18:43
    Imagine a game where a number of blank squares appear on the screen under a question, ala wheel of fortune. Contestant starts guessing letter rapid fire up to a max 0f 10 guesses. I have a dashboard that holds 27 buttons per row (A-Z and blank default). As the operator clicks on a given letter it sets Data1 value. Meanwhile the answer text is fed by an excel sheet. So, on OnSetText for the DATA1 field I have the following script.
    dim letter1 as xpTextObject
    dim letter1Vis as xpBaseObject
    dim Data1 as xpTextObject
    engine.getobjectbyname("LETTER 1",letter1)
    engine.getobjectbyname("LETTER 1",letter1Vis)
    engine.getobjectbyname("DATA_1", Data1)
    if Data1.text = letter1.Text then
    letter1Vis.Visible = true
    else
    letter1Vis.Visible = false
    end if
    A simple visibility switch based on whether two data field match. I think I am missing something simple and small. Helping out a fellow designer.
    Thanks in advance
    Malcolm Thorpe
    xpression design
    Malcolm Thorpe
    xpression design
  • 2.  RE: Need a little help with a simple script. (helping out a fellow designer)
    Posted 09-23-2024 09:08
    getObjectByName belongs to xpScene, so depending where this script is, use:
    Scene.getObjectByName or Self.getObjectByName
    Also, letter1Vis is redundant. Just use letter1. It has all the props and methods of xpBaseObject plus extra for text.
    Use the Xpression API documentation.
    Azathoth
    Son of Cthulhu
