Need help creating a countdown clock for an event.
  • 1.  Need help creating a countdown clock for an event.
    Posted 08-26-2016 22:20
    Hey there.
    I'm trying to create a countdown to an event coming up here in a few weeks and was wondering what I need to do to make that work. It needs to be a real time clock that will countdown to the event going from days, hours, minutes, and seconds. I was wondering if I could get any help setting this up. Thanks!
  • 2.  RE: Need help creating a countdown clock for an event.
    Posted 04-09-2021 19:15
    Patrick,
    Did you ever figure out how to do this?
    Daryl Judd
    Sbgtv
  • 3.  RE: Need help creating a countdown clock for an event.
    Posted 04-09-2021 20:50
    Hey Daryl!
    Here's a solution to your problem; just a quick 3-block solution using Visual Logic!
    Open up visual logic for your scene (The Orange and White Block button to the right of "Window"), and there's only these blocks that you need, highlighted in Yellow:
    The "Clock" block represents the current date and time.
    The "Encode Date Time" block represents the day and time you're counting down to. By clicking on the block, you can enter in values for this date.
    The "Time Delta" actually subtracts the two DateTimes, and outputs the Days, Hours, Minutes, and Seconds for you to use in whatever way you want!
    Zachary Fradette
  • 4.  RE: Need help creating a countdown clock for an event.
    Posted 04-10-2021 09:10
    Here is a scene you can import if you want a working example.
    https://www.dropbox.com/t/QKxL8jHBDS88aUd2
  • 5.  RE: Need help creating a countdown clock for an event.
    Posted 01-31-2024 05:35
    HI,
    The link is broken. Is it possible to send again. How to set target time on Tick-It?
    Basically I want to use it for Ramadan Countdown (attached) for 8 divisions.
    Please help me.
    Thanks.
    Mahibul Blank
  • 6.  RE: Need help creating a countdown clock for an event.
    Posted 02-16-2025 13:43
    Plz Share this Scene Again
    Shorab Khan
    Senior Motion Graphics Designer
    NTV, Bangladesh
  • 7.  RE: Need help creating a countdown clock for an event.
    Posted 02-16-2025 13:47
    Plz Share the Scene Again . The Link is Disable
    Shorab Khan
    NTV, Bangladesh
  • 8.  RE: Need help creating a countdown clock for an event.
    Posted 04-10-2021 14:26
    I see that some folks have inquired about how to do a countdown. Well, if you want to use Visual Logic to do it, it is pretty easy. We have created a video tutorial on how to do it a while back and posted it  on the XPression U. site on the Ross Video website.
    Here is a link to the specific tutorial on counting down to a date and or time in XPression with Visual Logic
    https://www.rossvideo.com/gallery/xpression-u/counting-down-to-a-date-or-time-using-function-blocks-in-xpression-visual-logic/
    Patrick Twomey
    Director of XPression Product Management
    [WebsiteUrl]
  • 9.  RE: Need help creating a countdown clock for an event.
    Posted 04-12-2021 11:39
    Thank you Patrick. When I searched "Countdown" only B150 and B192 lessons came up.
    Daryl Judd
    Sbgtv
  • 10.  RE: Need help creating a countdown clock for an event.
    Posted 02-01-2024 04:19
    You should search for "counting" down. You will find the B144 lesson :-).
    Rob van Rooyen
    Senior Graphics Specialis
    NEP The Netherlands
    Hilversum Netherlands
  • 11.  RE: Need help creating a countdown clock for an event.
    Posted 02-18-2025 09:44
      |   view attached
    Hi Patrick, Your tutorial was certainly helpful and thanks for sharing. I want to show all "00" once it reaches the target time.  How do I achieve that.  Thanks in advance.
    Ariful Alam Khan
    AGM
    ITCL
  • 12.  RE: Need help creating a countdown clock for an event.
    Posted 02-18-2025 10:15
    Use equal to with visibility of dummy text 00
    Main counter will be visibility  off and 00 object will on.
    [Wajahat] [Ali]
    [Team Lead] [RTG Designer]
    [Hum News][Capital-Islamabad] [Pakistan]
  • 13.  RE: Need help creating a countdown clock for an event.
    Posted 02-19-2025 11:24
    Ariful,
    There are several ways to execute this, as you will see the suggestions which are starting to appear in this thread. To get a countdown, you could use XPression WIdgets to count down and set a STOP time. you will just need to build multiple widgets and use CLOCK TIME to start the widgets and the Widget will stop at 00:00.
    Patrick Twomey
    Director of Graphics Product Management
    [www.rossvideo.com/XPression]
  • 14.  RE: Need help creating a countdown clock for an event.
    Posted 02-17-2025 00:12
    HI,
    there is U Tut available at ross university which helps a lot. rest I am sharing my How to hope this will help u as well.
    https://youtu.be/-Zrcty4Oizk?si=1bqyz4ZmBiJaAtBb
    [Wajahat] [Ali]
