Sent: 01-14-2025 12:53
Subject: Need help in ActiveX plugin and SDK" has been updated
You also mention "NMS web project". If NMS is a web based NRCS client, you may want to consider using the XPression HTML5 plugin instead of the ActiveX plugin.
Section 5.1.1 details the behavior or HTML5 MOS plugins: https://mosprotocol.com/wp-content/MOS-Protocol-Documents/MOS_Protocol_Version_2.8.5_Final.htm
To enable the HTML5 plugin in the XPression MOS Gateway:
And then use the address: http://<ipaddressofgateway>:9500/static/
To access the plugin.
Sent: 01-13-2025 11:44
Please help me any body know...
Irfan Memon
Broadcast Engineer
Samaa TV
Sent: 01-10-2025 10:34
After installing ActiveX and configuring the MOS gateway, I need assistance now so that the template will be stored in the story when I click the "add to story" button. I don't currently have a button event to execute this template add in my NMS story. It will function once I've coded it using your SDK. I need that SDK, so please ask the software team for assistance. Button events are displayed in the attached image for reference.
Irfan Memon
AM Technical Hum News
Cell: +92-322-8331512
