  • 1.  Obj Sequence
    Posted 13 days ago
    Kia ora
    I export an OBJ sequence within Blender with the 'export animation' box checked.
    I named the file 000000 so that the sequence/animation can load up - or be found - in Xpression.
    I import the very first file - object shows up fine.
    When I drag the OBJ 'sequence' from the materials manager to the scene director track. It only shows up with 1 frame.
    Is there another box I need to check? Or is Xpression not reading the sequential numbers correctly?
    I am trying to import an animated scene using  an OBJ file sequence exported through Blender.
    Any help, very much appreciated lol
    Whakanikoniko / Graphics
    Whakaata Māori
  • 2.  RE: Obj Sequence
    Posted 12 days ago
    HI,
    Try Use C4d Obj Sequancer it will work.
    [Wajahat] [Ali]
    [Team Lead]
    [Hum News] [Islamabad] [Pakistan]
