  • 1.  Open/Stinger Videos Freezing/Stuttering
    Posted 10-29-2024 12:01
    We've been having an issue lately of stingers/opens will either freeze completely after a second, or stutter through playback when we take them.
    We're using Overdrive and Xpression. The source video files have the same settings as our other video files. And when we go back and play them again, the files play out fine - no freezing or stuttering.
    Could it be a network issue? Something with Overdrive?
    JH
    Engineer Technician
  • 2.  RE: Open/Stinger Videos Freezing/Stuttering
    Posted 10-29-2024 12:07
    Are you storing the clips locally on the XPression or playing them over network?
  • 3.  RE: Open/Stinger Videos Freezing/Stuttering
    Posted 10-29-2024 15:20
    They're being played over the network.
    John Henry
    Technical Director
    WRGB CBS6
  • 4.  RE: Open/Stinger Videos Freezing/Stuttering
    Posted 10-29-2024 16:55
    In Rocket Surgery we usually keep video files locally on the machine, we make shares on the XPression machines themselves so they can be dropped in via network from edit machines and other areas of the business.
    To keep clips in sync we either use Clips Store if purchased or if the client hasn't purchased Clip Store we use some sync software so that all machines receive the same files.
    Someone from the XPression team might have more to say on this but that's our preference for handling videos.
  • 5.  RE: Open/Stinger Videos Freezing/Stuttering
    Posted 10-30-2024 07:06
    Hi everyone.
    John, try doing it this way:
    1. Creat bat  file with robocopy  string like this :
    robocopy  \\{XXX.XXX.XXX.XXX}\{FOLDER}\  C:\media\ *.avi /S /MIR
     (mirroring from  the net folder to local). And run this bat file using scheduler of your comp (exemple one time in 5 minet)
    2. If you use template links material, set in InBeforOnLine the next scrips
            Dim obj As xpBaseObject
            self.GetObjectByName("BG", obj)
            Dim mat As xpMaterial
            If obj.GetMaterial(0, mat) Then
                Dim shader As xpVideoShader
                If mat.GetShader(0, shader) Then
                        Dim name As String = shader.FileName.Replace("N:\{FOLDER}", "C:\media") 'changing path to local
                        shader.SetFileName(name)
                        shader.ReloadFile()
                End If
            End If
    Roman Yaroshenko
    chief specialist
    RBC-TV
    Moscow Russian Federation
