Sent: 11-14-2024 10:06
Subject: params getting corrupted
DataLinq should handle the parameters just fine but it will change the OIDs it receives. Instead of getting "team0.info.name" the parameter will be listed as "team0.info.0.name"
James Peltzer
Sent: 11-14-2024 10:04
For further info, If I change these individual structs to a struct array, the problem goes away. Will this be a problem for datalinq? I initially went with individual structs because they would always be present when I need to clear the info.
How does datalinq handle dynamic params?
David Levy
Lead Real Time Graphics Developer
ESPN
Charlotte United States
Sent: 11-13-2024 17:23
Update: the code is irrelevant, even if I change a view param, this breaks
David Levy
ESPN
Sent: 11-13-2024 17:21
Updated Template since first post:
<param access="1" constrainttype="STRUCT" name="Team Template" oid="teamInfo.template" stream="false" type="STRUCT" widget="default"> <value> <subparam access="1" maxlength="0" name="Application Color" stream="false" suboid="applicationColor" type="STRING" value="#E40F0F" widget="color-picker"/> <subparam access="1" maxlength="0" name="Rank" stream="false" suboid="rank" type="STRING" value="" widget="text"/> <subparam access="1" maxlength="0" name="Tricode" stream="false" suboid="tricode" type="STRING" value="" widget="text"/> <subparam access="1" maxlength="0" name="City" stream="false" suboid="city" type="STRING" value="" widget="text"/> <subparam access="1" maxlength="0" name="Name" stream="false" suboid="name" type="STRING" value="" widget="text"/> <subparam access="1" maxlength="0" name="Mascot" stream="false" suboid="mascot" type="STRING" value="" widget="text"/> <subparam access="1" maxlength="0" name="Logo" stream="false" suboid="logo" type="STRING" value="" widget="file-picker"/> <subparam access="1" maxlength="0" name="ALT Logo" stream="false" suboid="altLogo" type="STRING" value="" widget="file-picker"/> <subparam access="1" maxlength="0" name="Swatch" stream="false" suboid="swatch" type="STRING" value="" widget="file-picker"/> <subparam access="1" constrainttype="INT_CHOICE" name="Swatch Selection" precision="0" stream="false" suboid="swatchSelection" type="INT32" value="0" widget="default"> <constraint key="0">Logo - 0</constraint> <constraint key="1">Primary - 1</constraint> <constraint key="2">Secondary - 2</constraint> <constraint key="3">Bottomline - 3</constraint> </subparam> <subparam access="1" maxlength="0" name="Headshot Folder" stream="false" suboid="headshotFolder" type="STRING" value="" widget="file-picker"/> <subparam access="1" constrainttype="INT_CHOICE" name="Session Selector" precision="0" stream="false" suboid="sessionSelector" type="INT32" value="1" widget="default"> <constraint key="1">1</constraint> <constraint key="2">2</constraint> </subparam> <subparam access="1" constrainttype="FLOAT_NULL" name="Vault Score" precision="0" stream="false" suboid="vaultScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Uneven Bars Score" precision="0" stream="false" suboid="unevenBarsScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Beam Score" precision="0" stream="false" suboid="beamScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Floor Score" precision="0" stream="false" suboid="floorScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Pommel Horse Score" precision="0" stream="false" suboid="pommelHorseScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Still Rings Score" precision="0" stream="false" suboid="stillRingsScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Parallel Bars Score" precision="0" stream="false" suboid="parallelBarsScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Horizontal Bar Score" precision="0" stream="false" suboid="horizBarScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 1 Event" precision="0" stream="false" suboid="rotEvt0" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 2 Event" precision="0" stream="false" suboid="rotEvt1" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 3 Event" precision="0" stream="false" suboid="rotEvt2" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 4 Event" precision="0" stream="false" suboid="rotEvt3" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 5 Event" precision="0" stream="false" suboid="rotEvt4" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 6 Event" precision="0" stream="false" suboid="rotEvt5" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 7 Event" precision="0" stream="false" suboid="rotEvt6" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 8 Event" precision="0" stream="false" suboid="rotEvt7" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 9 Event" precision="0" stream="false" suboid="rotEvt8" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 10 Event" precision="0" stream="false" suboid="rotEvt9" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 11 Event" precision="0" stream="false" suboid="rotEvt10" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 12 Event" precision="0" stream="false" suboid="rotEvt11" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 13 Event" precision="0" stream="false" suboid="rotEvt12" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 14 Event" precision="0" stream="false" suboid="rotEvt13" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 15 Event" precision="0" stream="false" suboid="rotEvt14" type="INT32" value="0" widget="default"/> <subparam access="1" constrainttype="INT_NULL" name="Rotation 16 Event" precision="0" stream="false" suboid="rotEvt15" type="INT32" value="0" widget="default"/> </value></param>
David Levy
ESPN
Sent: 11-13-2024 17:16
Here's the offending code:
function clearTeamRotations() { for (var i = 0; i < 12; i++) { for (var j = 0; j < 16; j++) { params.setValue('team' + i + '.info.rotEvt' + j, 0, -1); } }}function updateTeamRotations() { clearTeamRotations(); // i is the rotation number in this session for (var i = 0; i < 8; i++) { var vaultTeam = params.getValue('womensSession1.'+ i +'.vaultSelector', 0); var barsTeam = params.getValue('womensSession1.'+ i +'.barsSelector', 0); var beamTeam = params.getValue('womensSession1.'+ i +'.beamSelector', 0); var floorTeam = params.getValue('womensSession1.'+ i +'.floorSelector', 0); // lookup the the team doing each event and set it's ith rotation to that event if (floorTeam != -1) { params.setValue('team'+ floorTeam +'.info.rotEvt' + i, 0, 4); } if (beamTeam != -1) { params.setValue('team'+ beamTeam +'.info.rotEvt' + i, 0, 3); } if (barsTeam != -1) { params.setValue('team'+ barsTeam +'.info.rotEvt' + i, 0, 2); } if (vaultTeam != -1) { params.setValue('team'+ vaultTeam +'.info.rotEvt' + i, 0, 1); } }}
David Levy
ESPN
Sent: 11-13-2024 17:14
Here's what it turns into:
<param base="teamInfo.template" name="Team 1 Info" oid="team0.info" stream="false"> <value> <subparam suboid="applicationColor" value="#B20044"/> <subparam suboid="rank" value="1"/> <subparam suboid="tricode" value="ARK"/> <subparam suboid="city" value="Arkansas"/> <subparam suboid="name" value="Arkansas"/> <subparam suboid="mascot" value="Razorbacks"/> <subparam suboid="logo" value="file:/D:/IMS%20Images/Primary/ARKANSAS.PNG"/> <subparam suboid="altLogo" value="file:/D:/IMS%20Images/Secondary/ARKANSAS.PNG"/> <subparam suboid="swatch" value="file:/D:/IMS%20Images/Swatches/ARKANSAS.PNG"/> <subparam suboid="swatchSelection" value="0"/> <subparam suboid="headshotFolder" value=""/> <subparam suboid="sessionSelector" value="1"/> <subparam suboid="vaultScore" value="1.0"/> <subparam suboid="unevenBarsScore" value="2.0"/> <subparam suboid="beamScore" value="3.0"/> <subparam suboid="floorScore" value="4.0"/> <subparam suboid="pommelHorseScore" value="0.0"/> <subparam suboid="stillRingsScore" value="0.0"/> <subparam suboid="parallelBarsScore" value="0.0"/> <subparam suboid="horizBarScore" value="0.0"/> <subparam suboid="rotEvt0" value="1"/> <subparam suboid="rotEvt1" value="4"/> <subparam suboid="rotEvt2" value="3"/> <subparam suboid="rotEvt3" value="2"/> <subparam suboid="rotEvt4" value="-1"/> <subparam suboid="rotEvt5" value="-1"/> <subparam suboid="rotEvt6" value="-1"/> <subparam suboid="rotEvt7" value="-1"/> <subparam suboid="rotEvt8" value="-1"/> <subparam suboid="rotEvt9" value="-1"/> <subparam suboid="rotEvt10" value="-1"/> <subparam suboid="rotEvt11" value="-1"/> <subparam suboid="rotEvt12" value="-1"/> <subparam suboid="rotEvt13" value="-1"/> <subparam suboid="rotEvt14" value="-1"/> <subparam suboid="rotEvt15" value="-1"/> </value></param>
David Levy
ESPN
Here's a sample struct pre-bug:
<param access="1" constrainttype="STRUCT" name="Team 1 Info" oid="team0.info" stream="false" templateoid="teamInfo.template" type="STRUCT" widget="default"> <value> <subparam suboid="applicationColor" value="#B20044"/> <subparam suboid="rank" value="1"/> <subparam suboid="tricode" value="ARK"/> <subparam suboid="city" value="Arkansas"/> <subparam suboid="name" value="Arkansas"/> <subparam suboid="mascot" value="Razorbacks"/> <subparam suboid="logo" value="file:/D:/IMS%20Images/Primary/ARKANSAS.PNG"/> <subparam suboid="altLogo" value="file:/D:/IMS%20Images/Secondary/ARKANSAS.PNG"/> <subparam suboid="swatch" value="file:/D:/IMS%20Images/Swatches/ARKANSAS.PNG"/> <subparam suboid="swatchSelection" value="0"/> <subparam suboid="headshotFolder" value=""/> <subparam suboid="sessionSelector" value="1"/> <subparam suboid="vaultScore" value="1.0"/> <subparam suboid="unevenBarsScore" value="2.0"/> <subparam suboid="beamScore" value="3.0"/> <subparam suboid="floorScore" value="4.0"/> <subparam suboid="pommelHorseScore" value="0.0"/> <subparam suboid="stillRingsScore" value="0.0"/> <subparam suboid="parallelBarsScore" value="0.0"/> <subparam suboid="horizBarScore" value="0.0"/> <subparam suboid="rotEvt0" value="1"/> <subparam suboid="rotEvt1" value="4"/> <subparam suboid="rotEvt2" value="3"/> <subparam suboid="rotEvt3" value="2"/> <subparam suboid="rotEvt4" value="-1"/> <subparam suboid="rotEvt5" value="-1"/> <subparam suboid="rotEvt6" value="-1"/> <subparam suboid="rotEvt7" value="-1"/> <subparam suboid="rotEvt8" value="-1"/> <subparam suboid="rotEvt9" value="-1"/> <subparam suboid="rotEvt10" value="-1"/> <subparam suboid="rotEvt11" value="-1"/> <subparam suboid="rotEvt12" value="-1"/> <subparam suboid="rotEvt13" value="-1"/> <subparam suboid="rotEvt14" value="-1"/> <subparam suboid="rotEvt15" value="-1"/> </value></param>
David Levy
ESPN
Sent: 11-13-2024 17:11
Ok, I did some more research. I can make this consistently when I try to params.setValue in one of those Structs.
However, when I first wrote this, I didn't have any code that wrote to those structs at the time, I was just editing view params at that time.
David Levy
ESPN
Sent: 11-08-2024 20:36
I have some struct tables, and my code is only reading from them.
At most, I have some code that hides them from streaming.
However, something is changing them from:
<param access="1" constrainttype="STRUCT" name="Team 1 Info" oid="team1.info" stream="false" templateoid="teamInfo.template" type="STRUCT" widget="table">
to: <param base="teamInfo.template" name="Team 1 Info" oid="team1.info" stream="false">
I promise I didn't write the "base" attribute
Also, the structs that are empty get deleted. I used to have 8, now I have 4.
I think this has happened twice.
I'm adding in the template, in case it helps.
<param access="1" constrainttype="STRUCT" name="Team Template" oid="teamInfo.template" stream="false" type="STRUCT" widget="table"> <value> <subparam access="1" maxlength="0" name="Application Color" stream="false" suboid="applicationColor" type="STRING" value="#E40F0F" widget="color-picker"/> <subparam access="1" maxlength="0" name="Rank" stream="false" suboid="rank" type="STRING" value="" widget="text"/> <subparam access="1" maxlength="0" name="Tricode" stream="false" suboid="tricode" type="STRING" value="" widget="text"/> <subparam access="1" maxlength="0" name="City" stream="false" suboid="city" type="STRING" value="" widget="text"/> <subparam access="1" maxlength="0" name="Name" stream="false" suboid="name" type="STRING" value="" widget="text"/> <subparam access="1" maxlength="0" name="Mascot" stream="false" suboid="mascot" type="STRING" value="" widget="text"/> <subparam access="1" maxlength="0" name="Logo" stream="false" suboid="logo" type="STRING" value="" widget="file-picker"/> <subparam access="1" maxlength="0" name="ALT Logo" stream="false" suboid="altLogo" type="STRING" value="" widget="file-picker"/> <subparam access="1" maxlength="0" name="Swatch" stream="false" suboid="swatch" type="STRING" value="" widget="file-picker"/> <subparam access="1" constrainttype="INT_CHOICE" name="Swatch Selection" precision="0" stream="false" suboid="swatchSelection" type="INT16" value="0" widget="default"> <constraint key="0">Logo - 0</constraint> <constraint key="1">Primary - 1</constraint> <constraint key="2">Secondary - 2</constraint> <constraint key="3">Bottomline - 3</constraint> </subparam> <subparam access="1" maxlength="0" name="Headshot Folder" stream="false" suboid="headshotFolder" type="STRING" value="" widget="file-picker"/> <subparam access="1" constrainttype="INT_CHOICE" name="Session Selector" precision="0" stream="false" suboid="sessionSelector" type="INT16" value="1" widget="default"> <constraint key="1">1</constraint> <constraint key="2">2</constraint> </subparam> <subparam access="1" constrainttype="FLOAT_NULL" name="Vault Score" precision="0" stream="false" suboid="vaultScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Uneven Bars Score" precision="0" stream="false" suboid="unevenBarsScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Beam Score" precision="0" stream="false" suboid="beamScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Floor Score" precision="0" stream="false" suboid="floorScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Pommel Horse Score" precision="0" stream="false" suboid="pommelHorseScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Still Rings Score" precision="0" stream="false" suboid="stillRingsScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Parallel Bars Score" precision="0" stream="false" suboid="parallelBarsScore" type="FLOAT32" value="0.0" widget="default"/> <subparam access="1" constrainttype="FLOAT_NULL" name="Horizontal Bar Score" precision="0" stream="false" suboid="horizBarScore" type="FLOAT32" value="0.0" widget="default"/> </value></param>
David Levy
ESPN
