Hi Mark,
You are correct, ASI is not supported with Ultrix. Due to the nature of the processing we use, it is not something that we plan on supporting in the future either.
our NK routers will route ASI if you are interested in an alternate solution.
https://www.rossvideo.com/infrastructure/routing-systems/nk/
Mike Pomerleau
Sent: 05-11-2024 09:23
Subject: Passing ASI
Is it possible to pass an ASI signal through an Ultrix router? I was unable to do that today. If I patched around the Ultrix, the signal went through to it's intended destination so there aren't any issues with the sending and receiving devices.
Mark Wetstein
