try this...
https://www.rossvideo.com/resources/ross-university/exporting-an-xpression-project-using-the-xpression-package/
if link doesn't work, google (Exporting an XPression Project Using the XPression Package)
Let me know =)
I normally import particular scenes from other projects and that copies all its content. But this should work for entire packages.
Alejandro Galvan
LA36 LOS ANGELES TV ACCESS
Sent: 10-02-2024 18:33
Subject: Path Issues when duplicating project
Hello everyone,
I often reuse my packages in multiple events and I normally duplicate the project folder, rename it and also rename the project file to the new event's name. That way, I can keep an "archive" version of all the iterations of the packages and events.
The issue with that is that all my image materials will keep the path with the original folder's name instead of the new folder's path.
Is there a better way to duplicate a project so that all materials and paths get adjust with the new project folder's name/location?
Thanks for the help!
Paulo Dias
Honolulu United States
