I should add that Lucid Track essentially supports every major and mid range camera tracking product/protocol on the market.
Sent: 11-19-2024 13:00
Subject: Prespective Camera
To put a tracked camera onto an SDI/2110 output using the FreeD protocol you need:
- XPression Studio (any type)
- XPression Chroma Keyer Option (this enables the camera tracking features in XPression)
- Ross Lucid Track (this software accepts the FreeD protocol and provides all the camera calibration tools)
Studio can be replaced with BlueBox if you also purchase Ross Lucid Studio. Lucid Studio provides an interface for controlling 3D objects in XPression Studio or BlueBox (as well as MANY other features)
If you don't purchase Lucid Studio and have XPression Studio, you will need to build all the controls natively in XPression or Dashboard or whatever. Lucid Studio is a more out of the box solution.
Lucid Studio Webpage
Sent: 11-19-2024 11:46
We have Vinten cameras using the free-d protocol.
Just want to confirm, that's not supported, correct?
Azathoth
Son of Cthulhu
Sent: 11-19-2024 11:06
Yes we support tracking in XPression.
However, I would recommend you check out Lucid and Voyager as well.
Sent: 11-19-2024 10:49
Hello Experts
In Ross Xpression there is Presp. Camera and there is Tracking / Global Camera Properties,
Under Tracking Field there is Disable , Global Tracker and Video tracker Drop down menu .
Does this function mean that i can use Physical Real world camera data in this section . if so then how can i achive this ?
can i link external physical camera data from my studio to get camera angle as per my requirement?
if i can do how can i do this .
please show me the direction .
Bam Bahadur Thapa
Freelancer Graphics Designer
Freelancer
Kathmandu Nepal
