I found a workaround. It seems like I'm facing the issue as far as I placed Datalinq block on the Visual Logic Editor. I put a Text on the scene which shows 0 or 1 with referring Excel via Dtalinq, and controlling the Visible of Quad on the scene. I don't think this would be best way, but it works now, thank you !.
Takuya Hoshikaya
Sent: 01-09-2025 22:56
Subject: Quad object controlled by Visual Logic works correctly on the Preview but on the Output
Thanks for feedback, but I can't find it on the Set Datalinq Properties...
Takuya Hoshikaya
Sent: 01-09-2025 05:32
Sent: 01-09-2025 03:42
I created a simple solution, hiding and showing the Quad controlled by Excel via datalinq.
- When the value is "0", the Quad hides.
- When the value is "1", the Quad appears.
I connected Datalinq box to Quad / Visible box on the Visual Logic. It works fine as far as I'm seeing Preview on the XPression, but is not working properly on the Output video. The Quad never appears on the Output.
Just as a trial I removed the VIsual Logic, the same Quad appears on the Output as I expected. Am I missing something?.
Takuya Hoshikaya
