  • 1.  Question about XPression cameras function
    Posted 07-30-2024 20:53
    Hi XPN users,
    I have a question regarding the 'Cameras' during the XPression function.
    1. What kind of work is the 'Cameras' function mainly used for?
    2. From what I understood, when I export a scene using 'Cameras', I understand that the screen is exported like a side, a high angle, or a low angle, not a front shot. Is the function of 'Cameras' correct that I understand?
    Dong-Geun Han
    Employee
    Youngdo B&C
    [Seoul] [Republic of Korea]
  • 2.  RE: Question about XPression cameras function
    Posted 07-31-2024 05:14
    Camera's are so you can move around there scene in 3D and choose a different angle to view from and take on air from.
    You can also use them for renderviews.
  • 3.  RE: Question about XPression cameras function
    Posted 07-31-2024 19:54
    Thank you so much for your response.
    Is it a feature that can be viewed through rendering when using a 3D object?
    So you're sending the scene to the camera's viewpoint, not the front?
    Dongkeun Han
    Employee
    Youngdo B&C
  • 4.  RE: Question about XPression cameras function
    Posted 08-05-2024 21:51
    You can change what camera is being viewed in the Viewport by selecting the Camera dropdown in the top left of the viewport, then select the camera you would like to view from.
    Separately, you can change what camera is being used to render the scene to an output by setting the camera to "active" in the settings:
    Finally, you can use a specific camera in a RenderView shader as part of a material
    Cameras can be used in ANY scene, no matter whether you're using "3D objects" (technically everything in XPression is created in 3D space) or just simple quads!
    Zachary Fradette
    United States
  • 5.  RE: Question about XPression cameras function
    Posted 08-08-2024 04:50
    Thank you so much for letting me know by attaching a picture!
    I'll practice it and check it out.
    Thank you for your kind explanation
    Have a great day!
    Dongkeun Han
    Employee
    Youngdo B&C
