Hi Miguel,
In Dashboard > Configuration > Inputs there are three tabs at the bottom of the page: External, Internal, and Substitute. If you click on Internal you'll see all the available internal sources.
You can assign an internal source to a crosspoint in Dashboard by going to Personality > Bus Map. Once there, select the crosspoint you want to assign the source to, and from the popup that opens click Internal > [source]
Hope that helps!
Cheers,
Aury Rukazana
Senior Software Developer
Sent: 01-09-2025 03:20
Subject: Recall internal input on Graphite from DashBoard
i know how recall from DashBoard all of 12-external input on Graphite, but...
how to do the same with internal inputs?
They have some numbers?
Miguel San Sebastian
