  • 1.  replace constraints of subparams in a struct table
    Posted 11-08-2024 14:29
    Having trouble replacing constraints in a struct table.  I've tried changing the template and also the instance.
    <param access="1" constrainttype="STRUCT" name="Womens Session Template" oid="womensSession.template" stream="false" type="STRUCT" widget="table">
                <value>
                   <subparam access="1" constraintstrict="false" constrainttype="STRING_STRING_CHOICE" maxlength="0" name="Vault" suboid="vaultSelector" type="STRING" value="None" widget="combo">
                      <constraint key="0">None</constraint>
                      <constraint key="team1">Team 1</constraint>
                      <constraint key="team2">Team 2</constraint>
                      <constraint key="team3">Team 3</constraint>
                      <constraint key="team4">Team 4</constraint>
                      <constraint key="team5">Team 5</constraint>
                      <constraint key="team6">Team 6</constraint>
                      <constraint key="team7">Team 7</constraint>
                      <constraint key="team8">Team 8</constraint>
                   </subparam>
                   <subparam access="1" constraintstrict="false" constrainttype="STRING_STRING_CHOICE" maxlength="0" name="Bars" suboid="barsSelector" type="STRING" value="None" widget="combo">
                   </subparam>
                   <subparam access="1" constraintstrict="false" constrainttype="STRING_STRING_CHOICE" maxlength="0" name="Beam" suboid="beamSelector" type="STRING" value="None" widget="combo">
                   </subparam>
                   <subparam access="1" constraintstrict="false" constrainttype="STRING_STRING_CHOICE" maxlength="0" name="Floor" suboid="floorSelector" type="STRING" value="None" widget="combo">
                   </subparam>
                </value>
             </param>
    David Levy
    Lead Real Time Graphics Developer
    ESPN
    Charlotte United States
  • 2.  RE: replace constraints of subparams in a struct table
    Posted 11-08-2024 14:44
    never mind, got it working eventually
    David Levy
    ESPN
