Hi Kevin,
there is no feedback or "ack"
its TCP so it's is just fire and forget
you can use DashBoard if you like to also build custom panels to send messages or if using StreamDeck you can just use the Ross StreamDeck plugin that is in all the switcher software downloads
Sent: 08-10-2024 02:38
Subject: Rosstalk on Carbonite ultra from another pc
Hi : i see the manual said send ross talk command (example key1 auto on)when create the ross talk network , i try from another pc use window command : 192.168.0.123:7788 , but can't see any feedback, can someone advise me how to get it!but i use companion use cc is work, thanks
Kevin Lam
