You can set up a small server within a custom panel using the OGLML listener tag. It operates in two modes: listening for incoming connections (server mode) or establishing a connection (client mode). In both cases, the listener tag monitors incoming data from the remote system. I've included two panels in a zip file: one acts as a listener for incoming connections, while the other sends a message to it using the rosstalk.sendMessage
command. You can also upload the panel to an Ultritouch device and run it directly from there.
Sent: 12-03-2024 11:03
Subject: rosstalk.sendBytesWithResponse
Marc, I came across this post while trying to figure out some TCP connection functions.
The code you had included the localhost 127.0.0.1 ip address and you mentioned you had a simple server running locally. What did you mean you had a simple server running locally? Was there something running on an Ultitrouch panel or something along those lines? Is there a way to load files on to a local device to setup as a simple server?
Seth Haberman
Associate Director of Live Broadcast Video
Gateway Church
United States
Sent: 08-28-2023 16:55
Hello Rich,
sorry for the delay. I've tested this with DashBoard 9.6.1 and seems to be working fine.
Here is a small example of a custom panel which communicates with a simple server I had running locally.
Each button would send a different integer value to the server.
You can see that the `sendAsBytesWithResponse` takes the provided value and a terminator; '0A' in this case.
The server receives the integer value and then returns a series of bytes followed by a 0x0A.
DashBoard then invokes the callback function where `result` is the data received from the server.
<abs contexttype="opengear" id="_top" keepalive="false"> <meta> <api immediate="true">function callback(success, sentData, result, exception) { var resultString = result.map(String); ogscript.debug('Got success: ' + success + ', sentData: ' + sentData + ', result: ' + resultString + ', exception: ' + exception); } function sendInt(value) { rosstalk.sendAsBytesWithResponse('127.0.0.1', 4442, value, '0A', callback); }</api> </meta> <button buttontype="push" height="108" left="21" name="Send 0" top="20" width="107"> <task tasktype="ogscript">sendInt(0);</task> </button> <button buttontype="push" height="104" left="21" name="Send 1" top="141" width="103"> <task tasktype="ogscript">sendInt(1);</task> </button> <button buttontype="push" height="94" left="150" name="Send 2" top="148" width="103"> <task tasktype="ogscript">sendInt(2);</task> </button></abs>
Hope this helps. Best regards,
Marc-André Parent
Sent: 06-30-2023 13:03
Are there any examples of using rosstalk.sendBytesWithResponse() ? I can get rosstalk.sendBytes() to work, but I need to get a response.
(Actually, even rosstalk.sendBytes() is a little weird in that the callback function is never called, but that's a different issue...)
rich helvey
access hollywood, nbc
